I have a strange behavior with the Closed HiHat. During step write or tap mode, I can set the normal and accent levels with no problem. But this cannot be saved. Once I saved it, and changed to another pattern. The level are lost. If I switch back to the same pattern, all the levels of Closed Hihat became accent.
Do you guys have the same problem or is it only in my built?
Could someone please confirm this?
Is this a Bug? Closed Hihat accent cannot be saved
Last edited by truman_k@yahoo.com on Nov 11th, '16, 16:09, edited 1 time in total.
No one has this problem? So this must be something wrong with my built?
Anyone has any idea which part of my built goes wrong?
I also have this problem with the Hi-hat accent not saving
Thanks Phil for spending your time to try this out.
I guess this must be the software problem? Maybe I should put this in the Bug list.
I can confirm this as well. Bug.
