Instr. selector selects wrong instruments?
Anyone has an idea on this?
For instance when select BD and program in sequencer it triggers LT / Same for AC that triggers SN??!
take off the knob. put the knob back on with the arrow pointing where it should be. done
Hi pistrix, i wish it was that simple
This is a bit more serious.
still checked diodes beside the instrument selector switch?
if the diodes be good then get the datashet from grayhill (http://www.grayhill.com/assets/1/7/mech_encoder_25l.pdf) and check your switch with a beeper.
you have to check with the HEX code table! no need to solder out that switch!
i had a similar issue, fixed the same way as SubStyler suggests.. just check the logic table and it will be quite obvious then where in the circuit the problem is.. Can't remember what it was in my case, short or a cold joint on a diode or something...
good luck
good luck
Hi rv0 and SubStyler, thanks for the info! I will into it.
SOLVED - cold joint was causing the problem due to the turning of the board a couple of times. Resoldered the reistor back and front of the PCB and it works fine now
good job!rkzr wrote:SOLVED - cold joint was causing the problem due to the turning of the board a couple of times. Resoldered the reistor back and front of the PCB and it works fine now
