Hi
my yocto work well but it has two problems.
1.Tap tempo or tempo: I can't change the tempo. The encoder work well because i can unmute and roll.
2. The scale leds is always on but i can change the scale.
Any idea ?
thanks peole
best regards
tempo and scale problem.
Did you solve this? I'm having the tempo issue.
hi
i can't solve this problem, all instruments work and sequencer run but i can't not change the tempo.
i tested the next:
1.The voltage in encoder is ok and the switch go to the IC7.
2. i changed the atmega and repograming it. I have the same problem.
3 i changed the IC7 but nothing
4. I try to sync whit ableton live but the yocto no detect the tempo.
in this moment i'm lost
any idea?
thanks
i tested the next:
any idea?
thanks
hi
any idea?
thanks
any idea?
thanks
