- Posts 7
Hey!
Just finished bulding the NAVA and looks that there is some kind of error in the build which makes firmware behave in a weird way. I did the INIT EEPORM procedure, but that did't help.
The problem is that length of all patterns by default is set to 256 and when I change that to 16 steps and save it the setting is immediately lost after the pattern have finished played.
Also track sequencer show weird numbers and shuffle amount setting page doesn't display correctly.
Thanks in advance,
kodek
- Posts 28
you have the wrong eeprom, its been covered
- Posts 7
dinsync wrote:you have the wrong eeprom, its been covered
yep, changed the EEPROM and sequencer now is working!
Shuffle screen still have characters messed up tho.
- Posts 65
screen could be a problem with the character set your LCD uses, since it is a different LCD model.
- Posts 42
good info - hopefully character set is listed in bom or some instructions.
