Hi everyone,
My Yocto is complete, bar a case. It's working, first time with no (2 v small) issues.
I'd just like to thank everyone who has helped along the way, given advice etc!!
Regarding TM3, I didn't see much about calibration however for those who don't know, when you start up your Yocto, play a clap sequence and twist the trimmer until it sounds how you like, really couldn't be simpler.
The unit its self sounds incredible, especially when I overdrive the volumes slightly.
The only two issues someone may be able to assist with are as follows:
1. If I play a sequence, any sequence with all volume pots turned right the way down, these is a quiet clicking sound that seems to be triggered by the rim shot sequence.
2. The middle tom/middle conga makes a slight humming sound when the switch is in midconga position, this is amplified if I touch the switches metal casing?
Any ideas, please let me know.
Anyway, thank you all so much, it's been a pleasure.
If you have any questions please ask here/other threads/pm and i'll try my best to help but remember i'm no expert.
I'll say I did take my time to make sure there were no solder bridges, the polarities were all correct and that everything went into their respective places.
The forum is a treasure trove so dig deep!
Jeremy.
				IT WORKS, PERFECTLY, FIRST TIME!
About 2nd question, if you installed an internal voltage transformer, this is common.
				Thanks for your reply however, I don't have an internal transformer, instead an external line lump.gihaume wrote:About 2nd question, if you installed an internal voltage transformer, this is common.
Cheers anyway!
Hi Jeremy,
I have the very same problem with the midtom, the hum also gets louder when I turn the pitch as low as it goes. I am using an internal transformer. Please let me know if you find a solution to this, I promise to do the same! Cheers!
I also have similar issues with toms and rimshot. Volume is all the way down but I can still hear sound/clicks when they are triggered by the sequence.
So any help would be appreciated.
I am getting clicking when the rimshot is triggered also... does anyone know why this might be...?
				Activate.uhc.com Made Simple – A step-by-step guide awaits you at activate.uhc.com to help you activate your UHC card with ease. Activate your UnitedHealthcare card easily at activate.uhc.com and access your health benefits online in just a few steps. Go to activate.uhc.com to register your UnitedHealthcare card and unlock your health plan benefits securely. Quick guide: Visit activate.uhc.com to activate your UHC card and manage your healthcare benefits online. Need to activate your UnitedHealthcare card? Head over to activate.uhc.com for simple online activation.
				Log in at activate.uhc.com to activate your UHC card and start using your medical benefits right away. Learn how to activate your UnitedHealthcare card online with activate.uhc.com for easy account setup. Step-by-step guide: Use activate.uhc.com to activate your UnitedHealthcare card securely and quickly. Get started with your health plan at activate.uhc.com – activate your UnitedHealthcare card today. Securely activate your UHC card at activate.uhc.com and enjoy 24/7 access to health plan tools.
				Go online to activate.uhc.com and activate your UnitedHealthcare card in minutes with simple steps. Manage your UHC benefits easily—activate your UnitedHealthcare card now at activate.uhc.com. Visit activate.uhc.com for card activation and quick access to UnitedHealthcare member resources. Learn how to activate your UnitedHealthcare card online at activate.uhc.com and start saving today. Fast and secure—activate your UnitedHealthcare card at activate.uhc.com to use your benefits.
				Get access to healthcare benefits by activating your UHC card at activate.uhc.com now. Register and activate your UnitedHealthcare card quickly using activate.uhc.com. Go to activate.uhc.com for an easy way to activate your UnitedHealthcare card online. Activating your UHC card is simple—just log in to activate.uhc.com and follow the steps. Guide to activating your UnitedHealthcare card online at activate.uhc.com.
