- Posts 134
Hello everyone
Today i received the Yocto kit
nothing is missing nothing is broken but the package was crushed in the middle with a little hole
and i thing no
something is broken but when i open it everything was ok
uff
maybe maybe in the future you can use strong box or some information on the box handle with care fragile stickers because i was lucky they didn't broke the main board
Thanks thanks for fast delivery e-lictronic
now time to order mouser projekt
BedroomMusic on May 9th, '16, 09:40, edited 11 times in total.
- Posts 134
hello
one the Power Supply part number C3 is electrolytuc capascitor 680/ 35 V on mouser bom what i order is 680 / 25 volts is this ok?
- Posts 519
BedroomMusic wrote:the Power Supply part number C3 is electrolytuc capascitor 680/ 35 V on mouser bom what i order is 680 / 25 volts is this ok?
Yes it is
- Posts 134
Hey im getting -0V on the -15V ,+15V is 13,4 V and +5 is ok 4,999V
im using Phihong Wall Mount AC Adapters 15W 15V 1A Level VI
orientation and value of all diodes and electrolytics is oky
any suggestions
- Posts 18
- Posts 18
With the DC supply you're using you'll receive the 0v/GND +15v and +5v (as this is the +15V stepped down), you will not however receive the -15V as you're aware.
I drew a little diagram below to demonstrate why this is, hopefully it'll help everyone understand.
DC: you get +15v at the top/peak of the cycle
AC: you get +15V at the top/peak of the cycle
however you'll now get -15v at the bottom/trough of the cycle
P.s I don't know how to make the photo smaller
- Posts 134
hej
Jeremy thank you for quick response and the answer to my problem
i buy Ac 15v 1A Oem Ac adaptor and is oky
i can give link to the shop is someone is interesting
http://www.rcs-elektronik.com.pl/index. ... ad-zmienny
now is 15.026
4.998
-14.988 multimeter is Unit UT61E True RMS i measure in dc mode
now is time for noise section
and thanks once again Jeremy
- Posts 134
Hi
when adjusting the trimmer in the noise section
I cannot get 130mV on pin 1 of the 4558 closest I can get is 100mV any suggestions
maybe i will do some modifications from Roland service manual
- Posts 134
hello
from service manual I've changed r131 to 100k and i put 10uf 35v electrolytic cap in R127 now the noise section is around 130mV but is jumping up and down ii the multimeter fals
- Posts 145
How are you measuring the noise? It needs to be in AC mode and measuring V RMS. Scope is preferred..
