I've started using the yocto in my home studio and notice a ground loop like sound from my 909 when connecting din-sync out from the yocto.
Would you suggest isolating all outputs on the digital board from ground (make them float) to adress this issue?
Instructions for a modification would be very welcome.
e-licktronic wrote: ...
In the Yocto there are two separate grounds too who also join in the power connector. Trig out Hum problem comes from that the trig ground is common with digital ground and not with analog ground. But it can be solve with using cable without the ground connected.
We will make a tutoriel how to modify the IO board to solve Trig OUT Hum problem without using non-connected ground cables.
