no low Tom and r237 is HOT(RESOLVED)
  • It actually looks like both R236 and R237 are getting hot...
  • Dear dasanalog,
    Check that U15 are in the right way. If it is try to replace it ( any common double AOP will do the job for the test ).
  • Thanks for the reply. U15 is in the correct direction, The tom has been working and only stopped after I did the noise revision that's in the service manual. This is why I am confused as to why it would stop. I upgraded the opamp in the master section so I have a spare 4558 I will put in to the circuit to test.
  • Vincent, you were correct! It was a bad opamp.
