Clap weirdness
  • xlarge wrote:
    It's a bit strange that my board is printed with "1.0" but it does not match pictures and eagle brd-file.
    Did i also get a prototype board? viewtopic.php?f=16&t=413&p=2602&hilit=1.0+match#p2602
    Dear xlarge,
    Please post a picture of your Clap section. If it appear that you receive a proto Yocto board contact Vincent: contact@e-licktronic.com.
  • Thanks for replying.
    http://quby.frontdesign.com/~xlarge/yoc ... o_clap.jpg
    Right. Emailed.
  • Confusion cleared up thanks to Vincent.
    I actually was looking at the prototype board eagle files and comparing to my board.
    I re-downloaded the schematics and board file now and they match what i've got. So i do NOT have a proto board.
    Clap is still more like a snare though :)
  • Any luck with the clap so far?
  • Nah, nothing new yet.
    I'm in the dark... So i'll do what i can. Replace the BA6110 and see what happens.
  • Is there a reference any where what i should see if i measure/scope with the ba6110 out?
  • Verfied all transistors, resistors and capacitors.
    Replacing the 6110 didn't do jack shit but going over all solder joints did.
    I think i had some trouble around R372/C128. Now i've got something that's closer to a clap at least.
    What do you think? Any obvious areas i should look at now?
    http://quby.frontdesign.com/~xlarge/yoc ... volume.wav
  • So i went over the noise section again (put in 68k @ R127) and now i'm getting this after a lot of fiddling with handclap trimpot.
    http://quby.frontdesign.com/~xlarge/yoc ... justed.wav
  • The clap on mine sounds similar to yours but the volume of the clap is very low. I'm not sure what would be the cause. I tried adjust adjusting the trims but as I make it louder it sounds a lot less like a clap. :?:
