what could I wrongly done?
there is 0V on minus 15
+15 and +5 are ok
polarization on diodes, el.caps etc checked, all ok
on other side of D2 is +0.07V
also every time I plug charger to the Power Jack
there is spark between plug and Jack
D2 dead?
any idea?
power supply problem (no -15) ***SOLVED***
I think I bought wrong charger 15V DC
It should be transformer 15V AC
is above correct?
logically thinking yes
how on earth you can get negative voltage from +15 DC
hmmm
is above correct?
hmmm
Yes, you need an AC powersupply instead of DC.
yep
thanks mate
thanks mate
No problem, have fun during your build!
I just connected 15V AC Transformer
+5.1 ok
+14.7 ok
but
-17.3 ??!! thats out of tolerance, isn't it?
is it possible that by connecting previously (by mistake) DC power adaptor instead of AC Transformer
I damaged Negative Voltage Regulator IC5 (7915) ?
or some other component?
+5.1 ok
+14.7 ok
but
Your power section works perfectly now. Negative regulator needs a little load to start working.
You can put like 2,1k resistor there and then measure.
I checked with 3.3k between 0 and minusjuicyboy wrote:You can put like 2,1k resistor there and then measure.
Reading is now -15.00
Thanks juicyboy for this tip
No problem. I asked this same question when I first started buildingtomektowski wrote:I checked with 3.3k between 0 and minusjuicyboy wrote:You can put like 2,1k resistor there and then measure.
@ tomektowski - where did you buy that power supply?
