Display is dead, no function, but all voltages ok
  • ....i checked the two connections from the CPU to the crystal. Continuity is ok, but there is only a little DC voltage (checked with oszillograph)...maybe the CPU gets no clock? How should the signal on CPU pin 12&13 look like?
    That would make sense that nothing is working at all.....
    Thank you!
  • ...and i found out one more thing....the 5V i measured on the Pin 10 (Power supply) on the processor is measured against the "GND" Test point TP1. not against the GND Testpoint on the ICSP connector - its just round 2,5V.
    These two GND test points seem not being connected with each other...shouldn´t they be? Is there something like a "analog ground" and "digital ground"? Again thanks for any information!
  • HAHA!!! Solved the problem. On the PSU board i discovered there was a "R40" missing, which is not mentioned in the building instructions and not even found in the .brd file!!!!!!
    Nava 1.02 board: add a bridge where R40 is written on the PSU board - near J10.
  • Yt.be/activate is the link used to connect YouTube to your smart TV or streaming device.
    Easily pair your YouTube account with your TV by visiting Yt.be/activate
    Yt.be/activate is the online activation page for YouTube on smart screens.
    Use Yt.be/activate to enter your code and link YouTube to your device.
    Yt.be/activate helps you enjoy YouTube on big screens without logging in manually.
  • Activate YouTube on streaming devices by visiting Yt.be/activate and entering the code.
    Yt.be/activate makes YouTube setup quick on TVs and consoles.
    Enter your activation code at Yt.be/activate to link YouTube instantly.
    Yt.be/activate is the shortcut to pair your YouTube account with supported devices.
    Watch YouTube on your TV by activating it through Yt.be/activate
  • Yt.be/activate provides a simple way to connect YouTube with smart devices.
    Activate YouTube on Roku, Firestick, or TV with Yt.be/activate
    Yt.be/activate is the one-step solution to sync YouTube with large screens.
    Use Yt.be/activate to enjoy seamless YouTube streaming on your TV.
    Yt.be/activate lets you link your YouTube account using a quick activation code.
  • Enjoy YouTube on gaming consoles by activating at Yt.be/activate
    Yt.be/activate is designed for quick YouTube setup on smart devices.
    Enter the device code at Yt.be/activate to unlock YouTube on your TV.
  • vizio.com/setup is the quick link to activate and configure your Vizio TV or device.
    Set up your Vizio Smart TV or soundbar easily by visiting vizio.com/setup
    vizio.com/setup helps you connect and personalize your Vizio device in minutes.
    Use vizio.com/setup to link your Vizio TV to Wi-Fi and streaming accounts.
    vizio.com/setup is your guide to complete the initial setup of your Vizio products.
  • Configure apps, internet, and settings for your Vizio TV at vizio.com/setup
    vizio.com/setup allows you to register and activate your Vizio SmartCast device.
    Get step-by-step instructions for your Vizio device setup at vizio.com/setup
    vizio.com/setup is the one-stop page for activating and customizing Vizio TVs.
    Easily connect your Vizio device to streaming services via vizio.com/setup
