ATMEGA1284P not working (TP1, TM2, LCD problems)
  • Sorry for my ignorance.
    I found the firmware here. viewtopic.php?f=25&t=864
    I will be trying to unbrick or program my chip and will update with details
    UPDATE: You can use 12v High voltage to change fuses on the m1248p, but you need to have a parallel port programmer: a serial programmer (ICSP) won't work for this Atmel chip.
    I measured the voltage at the chip in the programmer and it measures ~3.8V... in the nava board the voltage measured ~4.8 volts. I believe since the nava power supply can source more current I didn't see much of a voltage drop, but a voltage drop is obvious when powering the chip from my USB powered ICSP programmer...
    I conclude that this chip must be damaged. I have ordered new chips and will be programming it with the information provided in these posts:
    avrdude fuses and bootloader:
    viewtopic.php?f=25&t=1141&p=7130&hilit=tools#p7130
    newest firmware:
  • Hey guys.
    I bought new chips and I've learned a few things...
    - you CANNOT use a usbtinyISP programmer to program the m1284p microcontrollers. USBTinyISP only supports up to 64k flash devices. the m1284p is 128k flash. Thought avrdude says it's supported it's NOT.
    so you have to use ArduinoISP (no big deal)
    - the MOSI and MISO lines on the NAVA v1.02 boards are SWAPPED - if you try to use a standard ISP programmer header it will NOT work. This is a common mistake but I'm surprised they didn't test this out before shipping these out...
    So now with the correct setup I read my original m1284p: device signature reads 0xffffff - it's dead. cool.
    Here are the commands I used to program the new m1284p. Note you'll have to change COM on your PC (or to /dev... on linux or mac).
    Code: Select all
    avrdude -c avrisp -P COM5 -b 19200 -p m1284p -U efuse:w:0xFD:m -v
    avrdude -c avrisp -P COM5 -b 19200 -p m1284p -U hfuse:w:0xDC:m -v
    avrdude -c avrisp -P COM5 -b 19200 -p m1284p -U lfuse:w:0xD6:m -v
    avrdude -c avrisp -P COM5 -b 19200 -p m1284p -U flash:w:Nava_v1_028beta.hex:i -v
    Run the commands in that order
    My sequencer works now.
    the problem was indeed a faulty microcontroller. Hopefully this helps someone else.
  • Why User Experience Is the Secret Ingredient of Successful Digital Campaigns? of successful digital campaigns because it builds trust, engagement, and lasting customer connections.
  • It helps members activate their activate.uhc.com health plan for easy online access.
    At activate.uhc.com , you can register, sign in, and manage your health benefits.
    The portal provides a secure way to activate your activate.uhc.com digital account.
  • channel5.com/activate is the online link to activate and connect Channel 5 on your smart TV or streaming device.
  • Using Menards.capitalone.com/activate , you can complete your card setup in just a few steps.
    Menards.capitalone.com/activate helps customers unlock the benefits of their Capital One-issued card.
    At Menards.capitalone.com/activate , you can securely verify and activate your new card.
    Menards.capitalone.com/activate is the onlinepage to activate your Menards Capital One credit card.
    The site provides an easy way to enable online and in-store purchases with your Menards.capitalone.com/activate .
  • Quicken Download to simplify your personal finance management.
    Get Quicken Download on your device to track expenses and budgets.
    Quicken Download lets you organize your money with ease.
    Access Quicken Download by downloading it for smarter financial planning.
    Quicken Download provides tools to manage income and spending.
  • Track your bills and accounts by Quicken Download
    Quicken Download to keep your finances on the right path.
    Manage your money with the Quicken Download option.
    Get started with financial tracking through a Quicken Download
    Quicken Download makes budgeting and planning simpler.
  • Securely manage investments with a quick Quicken Download
    Quicken Download to gain control of your monthly spending.
    Quicken Download gives you tools to oversee your bank accounts.
    Stay financially organized with an easy Quicken Download
    Budgeting becomes stress-free with Quicken Download
