v2.003beta:
-Should fix encoder issue
v2.003:
-Fixed led scale bug
-Fixed pattern direction bug
-Fixed LCD special character bug
-Improved accent stability
-Fixed MIDI Clock lag
-Fixed DIN clock out phase
-Pattern start counting from 1 instead of 0
-Fixed Trig1 length when MIDI played
-Fixed group bug
-Improved Track mode fixtures
v2.002:
-First released
Official Yocto² Firmware
Thank you but I need a .hex or .bin file because I programmed with a TL866 programmer.
Please upload hex file. Thanks
Cheers Jos
Cheers Jos
Yes, Vincent pls upload hex file.
cheers
cheers
I have a freshly built Yocto2 where the encoder dial doesn't respond. According to posts on the forum, the way to fix it is to reflash.
I thought I might as well put the new firmware on from this sysex, but neither the 'start+stop' keypresses or the 1+3+5 keypresses mentioned in the user manual bring up any kind of bootloader mode - so how is it possible to transfer this? (Just trying to send the sysex after the Yocto2 has booted up doesn't do anything)
(for those doing the flash with hex - is it possible with a USB-ASP and avrdude? - if so would anyone mind sharing the correct command?)
for programming hex with pickit2:
avrdude.exe -c pickit2 -p m1284p -P -b -U flash:w:c:\tools_y\Yocto_v2_002.hex:i -v
fuses:
avrdude.exe -c pickit2 -p m1284p -P -b -u -e -U lock:w:0x3F:m -v
avrdude.exe -c pickit2 -p m1284p -P -b -u -U efuse:w:0xFD:m -v
avrdude.exe -c pickit2 -p m1284p -P -b -u -U hfuse:w:0xDC:m -v
avrdude.exe -c pickit2 -p m1284p -P -b -u -U lfuse:w:0xD6:m -v
avrdude.exe -c pickit2 -p m1284p -P -b -U lock:w:0x0F:m -v
change your file hex destination and choose correct programmer, pls.
cheers
fuses:
cheers
Can I has hex file pls? I flashed ma chip and it got no bootloader
Great! That worked, thanks. I used:lukep_gdansk wrote:for programming hex with pickit2:
fuses:
cheers
avrdude -c usbasp -p m1284p -U flash:w:Yocto_v2_002.hex:i -v
... with a generic ebay USB ASP (all pins except 5v connected, Yocto2 power on). Didn't need to set fuses again. Encoder dial now works. Now awaiting v2.003 hex
Still no flam with the latest update?
Thank you for updating the zip with the hex file
Thanks for the hex file.
Cheers Jos
Cheers Jos
