I'm starting a new post here, as posting (as I did) in a topic marked as "Solved" may not be the brightest idea...
I cannot adjust TP1 as TM2 doesn't change the voltage between TM1 and Ground (it is around -0.2v... Very weird)
I do have a working screen displaying info (like "adjust TM2...").
I've checked every IC orientation and they are all correct.
I've checked +5V on every IC in the sequencer section, and all the square marked pins have +5V, so we're good regarding power I guess.
If I try to init EEPROM, it seems to work (including the info on the display), but after init, I have <Start> (flashing), <Stop/cont> (solid lit) and the first <Scale> LED (solid lit), but <Play> (under pattern) isn't flasing, as well as <C1>... And of course, no sound, just an unpleasant buzz sound (getting stronger after 2 secs when the Nava is powered on).
I've looked for parts that could be heating, but every part on the Nava seems to be at a cool and safe temperature...
I've checked every connection around IC110A (which has +15V and -15V as it should on pins 4 and 11), and everything is good : to TM2, to TP1, to R695, R696 and R697 (and then to ICs111 and 114 pins 3), to IC118...
And also something really weird : all switches light up when pressed except step switches (1 to 16), pattern switches and beyond on the right (including the <Enter> switch)... But if I get my finger close from IC106 (74HC595) on the switches and pots side of the board, BUT without touching the pins, all those LEDs light up ! I've switched the 74HC595 with another one on the board, but the issue remains the same... Very strange !
Thanks in advance for your help!
