I have sample playback on Ride, Crash and Hats but no other voices are working.
I've done the initialise EEPROM to start and adjusted to 5V on TM2 but haven't adjusted TM1 yet. Also on V1.024 firmware.
I can hear some output on the VCO’s - though the snare sounds very strange - and all ‘drum’ voices exhibit very long decay when listening to the VCO’s. Also no output at the Envelope, but I guess that’s to be expected. Also no output on the Handclap, and Rimshot is very quiet.
I’ve read some people have had issues with M5218L chips, which I’m really hoping I don’t have to replace them, as there are 36 of them on the board !
The codes on mine are mostly “ 1602 ” though some are “ 1Z18 “
Otherwise, the volume of the crash is ridiculously loud compared to the hi-hats - which I think are the only thing working ‘correctly’ at this point.
All triggers seem to be working, and I think accents are also fine.
There’s some ground noise and digital (sounds like CPU processing) noises at the main output, which change pitch or mute with various button combinations. I’m guessing this is due to broken voices.
Any advice on the above would be very helpful! Really hoping to get this up and running properly soon,
