I've built my first two pairs of these Accent_Fixers, called MUX_SH.
In the BOM was added the
HFC4051YM013TR
And also the
SN74V4051AD
I think it doesn't matter which one you take.
I've took the HFC4051*****
With both pairs i have the same problems. And it is really hard for me to tell all the troubles.
If i built it back to the original Acc IC's it was runing without all problems again.
Firmware 1.024 (firmware 1.023 makes the same)
If i activate a step with 1 press, there is nothing to hear.
With 2 press, it is the Bd to hear, but to quiet.
When i press one time the step after the full aktivated step, the second step is played the drum quieter (maybe right)
But the 1 time pressed need without activated Accent everytime a 2 times pressed step on the step before.
With Accent, yeaaaaah <3, Yes,... This maybe can be right.
SD have the same problem. But there is the one time pressed step without accent not to hear.
Low Tom is maybe perfekt.
Mid Tom:
If i activate a step on the same place like the Bd, is automatc the the full accent on the Bd. The sound of the mid tom is a little bit distorted. When i delete the steps of the MT, the kick runs forward with full accent and the normal accent doesn't change it if i turn down.
The next instruments to the Ride are, so i mean ok.
The Ride, i dont know what this is doing.
On the first step it was like a Roll on some instruments. And on an other step it was an other random pattern. Maybe it was only an other setting of Accent?! I don't know.
It was a great pattern, but not to use for what i want to do
Sometimes the Bd was falling down with the volume like a to hard sidechain.
Have anyone also problems lik this?
Can you help me?
Midi notes (as expander) are runing with the same problems.
Now it is moddet to the old Version, and it works like it should do.
Thank you!
