Hello,
My Bassdrum seems to sound OK but the attack knob doesn't have any effect on the sound.
Where could i start to search to diagnostic the problem?
Thanks for the help!
				Nava 1.02 // BD attack has no effect
bump!
				Try turning the BD level down to mid position. Then you should hear it. BD level is distorted with new Mux_SH boards when turned all the way up. Attack won't be audible then.
				Has this been solved? Ive noticed on my 1.2 each instrument is much louder than my 1.1 and the individual out then causing the master output to crunch at full c/w - sounds very 90's but its not right. Also causing the kick attack fault you have written about.
