Over the past weeks/month I've been working on an Expansion Modul for my NAVA. Each instrument reveived additional parameters (pots) - 37 Pots / 3 Switches in total.
Sonic enhancement is really remarkable - I liked (most of) the sounds before - but with the expansion some sounds are taken to a new level
BassDrum - 4 additional Pots (3 famous + 1 new):
- PitchEnv Depth - sets the mod amount of the Pitch Decay
Frequency - sets the initial Tuning of the Oscillator
Noise - sets the Decay Time of the Noise portion (dirty)
Drive - Overdrives the Oscillator (extremly dirty)
Also includes some range extensions for existing pots: Decay, PitchEnv-Deca ('Tune' Pot), Attack (much more Attack)
- PitchEnv Decay - sets the Pitch Decay
Decay - sets the Decay Time of the Osc Amp (Noise portion already has a Decay Pot aka 'Tone')
Damp - actually a LowPass Filter for the Noise portion
Range extension: 'Tone' slightly increased range
- PitchEnv - sets the Pitch Decay Time
OSC1 - sets the level of OSC1
OSC2 - sets the level of OSC2
OSC3 - sets the level of OSC3
Noise - sets the level of Noise
RimShot - 3 additional Pots: (gets more out of the RimShot - fit it to the mix)
- Tune - sets the tuning
Attack - sets the level of Attack portion
Drive - overdrives the main oscillator
Timbre - chenges to overall sound dramatically (sounds like claves or even HiHats at higher positions)
Reverb - sets the 'Reverb' Time
Filter Switch - Off/LP/BP/HP
Cutoff
Resonance
Env Mod - sets the amount of Cutoff Mod by the HiHat AmpEnv / -100%..+100% Range
- ENV Switch - choose internal or alternative ENV - alternative ENV can also be normal/retriggered mode (retriggerd means it starts from 0 with every new trigger / normal starts from level at the time of trigger)
Attack
Decay
Availability is expected for January!
If you like what you see/hear I would be very happy if you sign up in the List of Interest:
https://goo.gl/forms/UqbLsMd6yx3DXQAZ2
Thats not a preorder - you'r not forced to buy if you sign. Just helps me to organise things better.
People who have registered will be contacted by email on important news/availability and be given priority in buying a kit.
