Here is a tutorial on how to mod your Nava with Mux_SH boards.
1/You must unsolder IC111 and IC114
If you don't have a good desolder iron you can cut each pin then unsolder pins one by one
2/You must unsolder C517, C518, C519, C89 (BD), C163 (SD), C164 (LT), C165 (MT), C166 (HT), C167 (RS), C168 (HC)
If you have Nava v1.02 PCB go to step 3 those capacitors are not on the PCB
3/Solder J15 connector
4/Solder IC111 and IC114 Pins Headers
5/Solder CMS components on both Mux_SH boards. Take care of IC orientation, the 45°line have to match red line
6/Cut three piece of jumper wire female/female in the middle
7/Solder wires on the Mux_SH board. Take care to to put the same wire color on the pin +, GND and -
8/Solder Pin headers on the MUX_SH boards
9/Connect both MUX_SH board to the Main board. Take care IC111 and IC114 are in the opposite way.
And connect Jumper wires to J15
10/Now update the Nava firmware v1.024 (or higher) by holding steps button 1, 3 and 5 when power up the unit
Old accent value are still saved in your old pattern, to get it working properly you must write new pattern
Enjoy
