I just got a Yocto and din sync works fine through the cirklon, but when I use the computer as a master with Ableton Live using Sync Gen, the Yocto will not start from the 1. It starts wherever I last stopped it. Has anyone else had this problem and can anyone help me?
Thank you!
Issues with Din Sync, Cirklon, and Sync Gen ll
Anyone... Bueller
If i remember you need to press Stop button twice in Ableton to send a "Stop MIDI message", then if you press play Yocto and Ableton should be in sync.tyrelwilliams wrote:I just got a Yocto and din sync works fine through the cirklon, but when I use the computer as a master with Ableton Live using Sync Gen, the Yocto will not start from the 1. It starts wherever I last stopped it. Has anyone else had this problem and can anyone help me?
Thank you!
Hi.
I'm having similar issue with Ableton Live 11 sending clock out into E-RM Multiclock (via audio / VST plugin).
The Yocto is then receiving DinSync clock from the Multiclock. Do you think the issue is the same as yours?
F.
F.
... I reply to myself: it is NOT the same issue. When I double-stop Ableton Live and then start it again, the Yocto is still out-of-sync :-/
F.
F.
