For the last months I've been slowly putting together my Nava. So far I've traced every part from a vast amount of different suppliers (whichever was the cheapest). I've got all parts apart from the PSU (and some nuts that fit on the neutek phone connectors -they're not metric are they?).
As you all know the required PSU-specs are: Non-regulated AC-AC Power supply 15V 1000mA 15VA . I'm located in Belgium, so I need one suited with a EU-plug and also a 2.1mm barrel plug as an output-connector.
From other threads I've read that 16v and 18v PSU's suffice as well. I've searched for PSU's with these criteria as well, but to no avail
So far the only adequate PSU I've come across that was in stock and could be shipped to belgium was from a Swedish store and would have cost me, all in all, around 70 euros, which is expensive I think, when you consider some rare occasions where I came across suitable alternatives that were always out of stock, the PSU's costed around 15 euros.
I often came across some of the right-spec'ed, in-stock, cheaper psu's but nearly all of them were suited with a UK-plug. I'm not sure but, is it possible -and advised- to get one of these with a right interpiece so it fits in a EU power socket?
I'm not a professional and don't know much about electronics and current and psu's. So sorry if I'm totally missing the point here and making owt out of nowt.
Any leads to where I may find a proper PSU will be very much appreciated!
Many thanks in advance,
Thomas
