I have a problem that I would need some guidance for.
I have started assembly on the Yocto board, passed the Power Supply assembly and completed the Noise section assembly.
At the point in the manual where you say
' I did so and everything checked out perfectly.Test 4558 power. The red dot +15 V and green dot -15V (roughly 5%).
I then proceeded to install the opamp IC and the transistor.
At that point I proceeded to tweek the pot to arrive at the required ac voltage reading you specify in your guide as
.Adjust the TM4 trimmer for 130mV on pin 1 of 4558. To measure, use a voltmeter in AC mode (AC)
This is where the problem kicks in: the minimum voltage reading on pin 1 I can achieve by turning the pot is 0.48VAC (instead of the =.13VAC you require).
I checked all the values of the components I placed into the board and they all seem right.
Do you have any pointers for me on where to look?
Here is an image of my board:
