Ride distorts terribly when pitched up ---> https://clyp.it/tho4p3ql
Crash is barely audible.
Low tom clicks badly ----> https://clyp.it/oo3tt34d
BD attack doesn't work but I'm waiting on a rework station to de-solder IC13 socket since I broke IC113.
The snare....sounds good!
I've tried swapping ICs (IC110, IC111, and many extras ICs I had for the sequencer section. I should have wrote down which ones..) with no luck.
I've checked traces from the .PDF Bottom and top, and from what I could understand in the schematic .PDF.
I've checked solder joints dozens and dozens of times. Went back over them. They all look fine to me.
I've checked ALL power voltages across the board, and they are correct. I have dialed in +5.00V at TP1.
My wire connections in the housings are finicky. I've used the ones from the Tayda BOM and I have to mess with them to get a solid connection, otherwise the sound keeps cutting in and out. They seem to have too much play when they are seated in the connectors. I will try to find a solution to this.
I really doubt this, but I don't suppose this can have anything to do with my buggy OS? I'm experiencing what this user is here /viewtopic.php?f=25&t=1255 , except on top of that I am not able to get a 1 bar loop running. Pattern edit will play 1 bar (lets say A0), then go to A1 with 256 steps. Nothing saves. Only way i can test voices is by pressing 'Start' over and over, which triggers all voices.. I will update to newest OS once I find a USB to MIDI cable..
I really don't know what to do. This is basically my first (real) DIY project and most voices are fucked. I'd suspect the HH, Ride, and Crash has something to do with the DAC section, but i'm not sure. Like i said i've checked the traces from the .pdf traces, which were good, but I can't find IC110 on the .pdf scheme.
I would kiss on the mouth anyone who could give me a hand. I'm getting desperate and I'm at a loss of what to look for. Should I just buy all new ICs in sequencer and master section and swap them?
Here are some images of the component side..http://imgur.com/a/CSm1A
Thank you to anyone in advance.
