Can I just confirm we do indeed run a wire from P1 to P1 on the revised1.01a board?
Also can anyone with this board please confirm if buzz issue with bass drum is resolved?
thanks
Demos
1.01a Bass drum wire p1top1
Thanks
Starting bass drum tonight. So far so good
I have also finished 2 1.01a navas and no bd buzz on them
Quick question, what does P1 and P1' mean? I was looking at the instructions for the bassdrum here (http://www.e-licktronic.com/en/content/ ... e-bassdrum) but from the PCB diagram of the bassdrum section I didn't see anything labeled as "P1" or "P1'".
Thanks,
PortableFishy
Thanks,
PortableFishy
"IMPORTANT for the mainboard v1.0l owner: refer to this TOPIC before to start this section. For the V1.01 owner connect a wire betwwen P1 and P1'"
The above is written in red just below the parts list. I believe it was added as a revision so the pictures in the guide do not document this.
The picture in this post that KlangGenerator kindly posted is all you will need on this matter.
If you look at your main PCB at the bass drum section, you will see the area where KlangGenerator has added the bridge (blue wire).
Hope this makes sense, let me know if you need more info.
Thanks for the update, I just noticed the picture by KlangGenerator which is very helpful!
