decoder303 wrote:I understand that the tone pot acts as balance pot between the two bridged T-networks which resonate at different frequencies, but nevertheless you change the pitch turning the tone pot, I don't know why you can't agree here...
my understanding of the language might be a bit broken, but as far as i know, pitch is frequency
there's no change in frequency happening
but don't trust me, trust Roland.. the parameter is labeled TONE
there
is a place where actual frequency is being changed, and there the parameter is labeled TUNING
How'd you explain a musician what the tone pot does? I'd say you change the pitch of the body of the snare, he'd listen and he'd agree
see how Roland labeled the parameters on the front panel, i believe these devices were targeted at musicians
this is closer to mixing between two oscillators, or between two audio channels on a mixer than it is to changing pitch
here's your recording (from the beginning where you turn the TONE parameter):
in the middle you can see the two resonators together.. the lower one is at about 320Hz the other one is at about 550Hz in your case
another question about snappy, the snare sounds a bit thin, all other instruments sound fine.. I have measured 130mV rms at R127, I calibrated the clap.. toms sound nice, maracas sound nice.. I already tried the changes suggested in the service manual..
this was how it sounded before I swapped the cap, so ignore the wrong pitch focus is on snappy:
well, i compared it quickly to my snare from one of my first tracks.. when we ignore the "body" frequencies the snappy seems roughly comparable
i can't record a reference sample anymore because i modded my snare to increase the snappy decay time
perhaps compare yours to 808 samples from a sample library or so (if nothing else, you could get the audio from my first youtube video of the yocto, it was panned left, with no processing/fx, and no mods yet)
