2SA798 - defective/fake/replacement
  • You can send the defective transistors to E-licktronics.
    E-licktronics will replace them. Vincent said me that it can happen... unfortunaly.
  • 2N3906 is even much better than mentioned one.
  • Galaxy3000 wrote:Just want to report the problems/experiences I had with the 2SA798:
    1 of 3 of the 2SA798 I received with the kit was defective, one transistor inside was working the other not (happily I tested them before soldering in)
    I decided to take the plunge and ordered two replacements (about 13€ for both) on ebay - The 2SA798 I received from Hong Kong are FAKES. 2PNP's with common base instead of common emitter. :cry: :cry: :cry: (asking them for refund)
    Then instead of buying another overpriced 2SA798 I decided to replace it with 2 matched 2N3906 - WORKS perfectly on the Handclap!!! I bought 20 of them but already found 2 matching within the first 4 (difference of 2 in hFE / 1mV in Vbe - pretty good).
    Should work on HH and Crash circuits too! On non of the circuits they are carrying a audio signal btw. just ENV!
    So, if anybody else has to replace a 2SA798 I highly recommend to take 2 matched 2N3906 instead!!! according to this site: http://yusynth.net/Modular/EN/ARPVCF/ 2 matched BC557 should work too! Only drawback is that the legs need to be bended to the right position!
    Mind sharing how exactly you put those two 2n3906 in the pad?
    The SA798 pins should be BCECB. The 2n3906 is EBC. So according to this I put my two 2n3906 together like this:
    Unfortunately it doesn't work like this... :(
    Edit: It works perfect! There was another bug causing the HH not to work.
  • I'm sorry to hear it didn't work for you - the configuration looks good! I did it exactly the same way.
    well, I always avoid to get as close to the transistor housing with the soldering iron and leave at least 10mm of the legs above the board because transistors easily get damaged by overheating.
    Do you have a possibility to test the transistors? most multimeters have at least a diode-checker, u could check the '2 diodes' of the 2N3906 according to this drawing:
    the multimeter should give u a value in mV or V then (about 680mV) for both diodes - if either check gives no value then the transistor is defective
  • Lowes.syf.com/activate is the online page to activate your Lowe’s credit card online.
    It allows Lowes.syf.com/activate cardholders to securely enable their new card for use.
    The site provides a quick way to activate and manage your Lowes.syf.com/activate account.
    Lowes.syf.com/activate ensures your card is ready for purchases and rewards.
    It’s the secure portal for activating Lowes.syf.com/activate issued by Synchrony Bank.
  • Cardholders must complete activation at Lowes.syf.com/getstarted before using their card.
    Activating your Lowes.syf.com/activate online is simple through Lowes.syf.com/activate.
    Lowes.syf.com/activate is designed for safe and convenient card activation.
  • Why User Experience Is the Secret Ingredient of Successful Digital Campaigns? of successful digital campaigns because it builds trust, engagement, and lasting customer connections.
  • It helps members activate their activate.uhc.com health plan for easy online access.
    At activate.uhc.com , you can register, sign in, and manage your health benefits.
    The portal provides a secure way to activate your activate.uhc.com digital account.
  • channel5.com/activate is the online link to activate and connect Channel 5 on your smart TV or streaming device.
