Hi everyone!
One question regarding the left output from the NAVA: I only get very, very low output out of it. The mono/ right out is perfect. Anyone with the same issue or an idea why this could be? Why is there a stereo output anyways? Are some instruments panned a bit when using the stereo out?
Thx
left master output
Yes the summation of some instruments are not symmetric and this gives panning of these intruments.KlangGenerator wrote:Hi everyone!
Thx
Thanks! Just found out that the M5218L in the master section was defective. Works as it should now. But there is yet a difference in terms of sound on both separate and mix outs. The mix out is a tiny bit noisier/ distorted. This especially affects the lower frequencies on bd and toms. They get lost a bit due to slight distortion...AonFluX wrote:Yes the summation of some instruments are not symmetric and this gives panning of these intruments.KlangGenerator wrote:Hi everyone!
Thx
Hope Vincent is still working on this...
Hi - is there any indication of how much each instrument is panned left/right?AonFluX wrote:Yes the summation of some instruments are not symmetric and this gives panning of these intruments.KlangGenerator wrote:Hi everyone!
Thx
Can the pan be changed?
Thanks,
Flavio.
Here is an interesting post where a guy tried to simulate how panned are the instruments regarding their resistor in the stereo summing section. You should also be able to find the actual values of resistors you have put on the Nava in its schematics (last page (15)) so you know what value and where they are.
Merci gihaume!gihaume wrote:Here is an interesting post where a guy tried to simulate how panned are the instruments regarding their resistor in the stereo summing section. You should also be able to find the actual values of resistors you have put on the Nava in the schematics (last page (15)) so you know how much and where they are.
But, in the end: how much does it really make sense to use stereo out on the Nava? I mean... all other TR boxes have single/mono outputs for the summing signal... (ok, almost all TRs... 626 and 909 have stereo out).
F.
It's a little plus to help getting a better sounding result when you don't have 10 inputs on a mixer. But it's not a restrictive thing in any way. You could just use only one of the output and the panning will become variations in levels that anyway you will control with the level knobs.
Totally agree!gihaume wrote:It's a little plus to help getting a better sounding result when you don't have 10 inputs on a mixer. But it's not a restrictive thing in any way. You could just use only one of the output and the panning will become variations in levels that anyway you will control with the level knobs.
F.
