Hello,
i'm just finished to assemble the transistors for the HIGHTOM section by following the manual and notes from http://derek.trideja.com/nava/pages/nav ... endum.html and i was verifying VCC for 4069UB i got that :
- HIGHTOM 0V
- MIDTOM 0,1V
- LOWTOM 3,3V
- SNAREDRUM 2,5V
P.S. : i have 30V for M5218L in every completed parts
is it normal at this test phase ?
Thanks a lot
G.
MIDTOM / HIGHTOM : no power on VCC for 4069..
update : i soldered all the IC's for HIGHTOM and this is OK.
MIDTOM is still at 0V. I checked too on the zener ..
Got the same issue, I assume it's normal to have 0V for the 4069 when M5218L aren't soldered cause they seems to provide the power supply for the 4069. But when everything is soldered, i still have low voltages for the 4069 like:
Snare: +/- 2.5V
LT: +/- 3.5V
MT: +/- 3.5V
HT: +/- 9V
So i'm wondering if they should get +/- 15V like all other IC in the circuit or if this is normal.
Have you finished yours and tested it? Everything work as it should despite those weird voltages?
Thanks
Snare: +/- 2.5V
LT: +/- 3.5V
MT: +/- 3.5V
HT: +/- 9V
Thanks
