All of a sudden, my instrument select button is enabled on startup, and I cannot turn the mode off! If I press any instruments, it selects them. It acts like the button is held down. I tried reflowing the solder joints in the area, just in case. It did not work.
Has this happened to anyone?
Instrument Select button always on
Check your soldering on the caps underneath the buttons area. I had a stuck CH button that was remedied by flowing the button's associated cap.
Sounds like you will need to desolder and replace it. Concerning the kit switches, read what I wrote in this thread:
viewtopic.php?f=24&t=1062&p=6397#p6397
