I just finished my yocto and love it quite a lot! Worked fine from first power on and sounds beautiful.
After a few days now, one of the sequencer switch LED's (the second one) sometimes does not work when I power it on, the switch itself does though. By now it always got to normal behavior after a time of use but I wonder what might be going on there.
Any ideas anyone?
EDIT: The first time it started with being a bit dim. The last time getting bak to function was with a short period of flickering. Both was in no way connected to pressing/using the accomplishing switch (of course I tried repeated tapping around on it...)
You might also want to check your solder joints. I had some switch leds that did not come on at all. My multimeter said everything was connected; I only saw the fault when hooking up a scope. I fixed my LEDs by reflowing the solder joints.
You could try reflowing all the solder joints on the path from the shift register to your malfunctioning LEDs. There are just five: one shift register pin, both legs of the 220 Ohm resistor, both legs of the LED. Be careful with the 220 Ohm resistors in between the switches. If you touch the plastic of the switches with your soldering iron it will melt.
jvq wrote:You might also want to check your solder joints. I had some switch leds that did not come on at all. My multimeter said everything was connected; I only saw the fault when hooking up a scope. I fixed my LEDs by reflowing the solder joints.
Thanks a lot! Reflowing just the LED connections did not work but doing the resistor and shift register seems to have solved it now.
Activate.uhc.com is designed for new members to set up their UHC login credentials.
Accessing personalized care tools is simple once you activate at Activate.uhc.com Activate.uhc.com connects you to claims, providers, and wellness resources.
A one-stop activation page for Activate.uhc.com insurance members.
Use Activate.uhc.com to create a secure account for health plan access.
Activate.uhc.com gives members quick access to benefits and coverage details.
An easy way to activate your Activate.uhc.com insurance account online. Activate.uhc.com simplifies account setup for all UnitedHealthcare members.
Unlock UnitedHealthcare’s digital tools through Activate.uhc.com Activate.uhc.com is the starting point for managing your health insurance online.
From claims to ID cards, it all begins at Activate.uhc.com Activate.uhc.com is a trusted link for activating your healthcare account.
UHC members can activate and access their plan 24/7 at Activate.uhc.com
The secure member activation page for Activate.uhc.com plans. activate.uhc.com helps you stay connected with your health coverage online.
homedepot.com/mycard is the online portal to manage your Home Depot credit card online.
Access and track your Home Depot card account easily through homedepot.com/mycard
Make payments, check balances, and view statements at homedepot.com/mycard homedepot.com/mycard allows you to manage your Home Depot credit account securely.
Quickly log in to homedepot.com/mycard to pay bills and review transactions.
