				- Posts 89
						Ok guys, it's getting annoying     After disassembling the Nava the 3rd time to fix the bassdrum buzz I had to do it again today after I noticed that there is a problem with the open hihat decay which wasn't here before. The problem seems to be located in the envelope section somewhere, but I am a bit stuck at the moment. To exclude bad solder joints I already reheated them..
it triggers, decays and it looks like it gets triggert again but with lower amplitude, it sounds like there is a bit of delay on the hihat.
here are 2 measurements, one at the output of the hihat and one at the base of Q52..
A hint would be much appreciated? A problem in the area of C135 or Q84?
				- Posts 69
						I also had a Problem with the OH decay out of nowhere.  After swapping several parts I found that the issue is the 1.09 Firmware! After I installed the 1.07 firmware my hats  worked fine again!
				- Posts 89
						yeah was out of nowhere here too.. strange, since they worked fine until yesterday and I was using 1.09 since it was released.. will try it tomorrow, thanks for the info..
				- Posts 69
						In my case I guess I was so busy with the snare that I didn't test and use the Hi-Hats. I only noticed it later and didn't make the connection with the firmware.
On which side of the PCB did you cut the trace for the BD? Do you care to take some pictures of your mod? I'm a bit worried to do that so I'd like to be absolutely sure not to mess up anything again.
CHeers
				- Posts 89
						it was for sure fine here before, I already recorded some tracks with the nava and would have noticed this problem for sure if it already would have been there..
cut the trace at pin2 of the ic (you can't see it on the picture since the wire is on top of the cut.. be carefull, since other traces are pretty close here. The other cut is made at pin3 of the pot. both cuts on the component side which you see on the fotos.
				- Posts 89
						it's a problem with the global accent settings.. try global accent on every second step and place open hihats on every 4th step.
				- Posts 23
						Same here, i already posted that problem earlier. The hihat decay is way too short. First thought was i damaged some parts...
I built the whole section from scratch again, at first it worked, but after the Nava was off for some days, the decay was short again. I swapped some transistors around and somehow it worked like it should but  I don't know why. After several days off, the decay was short again.
Have to try firmware 1.017 if this will do smething...
				- Posts 89
						no, that's not the same problem. the hihat decay is fine. The problem described here is related to the global accent. if you set step 1 for an open hihat and set step 3 as global accent the accent on step 3 will alter the hihats decay, if the decay setting is long enough.
				- Posts 23
						ok...then i have no clue why the decay on my hats are too short...have to go on searching...
				- Posts 69
						decoder303 wrote:BD fix...
Works like a charm
