Wonder whats up with this since several of us have this problem.
I have not managed to solve mine yet.
my solder uses a colophony based flux. and is acid free. on the german wiki page of colophony it looks like that it doesn't need to be cleaned, it even protects from corrosion and oxygen. so i assume i can leave it? with the enclosure i won't see it anyways...momo wrote:With regards to removing flux, first check your solder's data sheet to see the kind of flux. If it's RMA ('rosin mildly activated'), the manufacturer may suggest the flux is ok to remain on the PCB following soldering. If your solder has an RA type flux ('rosin activated') then you'll almost certainly need to clean the flux residue away since it can be corrosive.
