OK, Partia Success.
Edited... see additional text after original post...
Almost by accident, the problem where you still have sound, but the different MUX boards don't work (don't add accent, or don't appear to change the sound) on my v1.02 as above was fixed by... re-running the EEPROM initialisation!!!!
I was swapping out various ICs in an effort to see if anything worked and despite the EEPROM chip being fine, I put back an old one (when I first built this machine) and suddenly the accent was back for the instruments attached to IC111....
As I'd also swapped a few 595's at the same time, I put back the other EEPROM chip and it stopped working again. So I ran an init with the non working accent EEPROM and bingo, all working. So the init must do some kind of calibration associated with the MUX boards/accent voltages etc and needs to be re-run after you have swapped / changed / fixed / re-soldered your MUX boards....
I now have all 4 MUX working, in either slot - just need to re-init the EEPROM after swapping them around - I hope this helps someone in a similar situation and may explain a lot of the issues people have had, particulalry with mux in IC111.
Just to be clear, I didn't have the problem of muting, i.e. when the MUX were installed I still heard all instruments, just no accent noticeable on HC,RS,HH,CY
UPDATE... However...
After a few repeats of a pattern the accent slowly disappears. I think it actually is stuck on. So you hear no difference. Almost like the S&H gets so charged up that it never stops!
So resetting the EEPROM seems to only temporarily fix...
Meanwhile, my oshpark order of the mux lite boards arrived today and I've just had enough time to build one and its working perfectly, first time in 111. So I think there must be something in the tolerances of some builds that mean slot 111 is very susceptible. If you have issues like these I can recommend the lite boards as a potential fix. I ordered 6 boards, so have 2 spare if anyone wants to try. Even happy to build and test them in my machine and send assembled. Feel free to message.
Update2. So built 2 mux lite and have them both in this machine now. I was experiencing strangeness still, BD accent would cause HH to go quieter... scoped the output HH_ACCENT from the mux and could see it triggering fine. So confirming the mux boards were working. Also now the CP and RS were fine. Traced the accent circuit thinking 2SA798, removed tested all good, then finally after removing Q52, tested fine, and resoldering i thought I'd just double check TP1. 10.5v... what? It was bang on 5v last time I checked... I guess maybe the mux lite draw less? Anyway, adjusted down to 5v, reset EEPROM again and finally all accents working and stay working! Not sure if it was the TP1 adjustment or the resoldering of Q52. But combo of those and the mux lite and now two fully working machines!
MUX_SH board mod tutorial
From what I have gathered, this MUX_SH mod is required for all Nava PCB versions to have correct accent triggers? Is this correct? I am about to start a Nava 1.02 build. I have the 2nd noise source for the snare / clap. I want to try to just do this correct in one shot. Any advice would be appreciated. I would also be interested if anyone has extra MUX_SH boards built laying around, if they are interested in selling one to me. It looks a little more complicated than my skill. I can do basic soldering, but have never soldered IC chips to PCB. Thanks.
For the lady talking about judi online indonesia, bandar togel terbaik, situs slot ternama, menang casino, agen situs, situs bandar togel online terpercaya, apa game slot, online situs, slot via pulsa telkomsel, bandar togel online terbaik, I highly recommend this conversational tone for login tajir4d info or nama situs togel online, slot yang gampang menang, situs slot yg terpercaya, main slot, situs game slot online resmi, togel online terbaik, toto slot pragmatic, slot dan togel, bandar togel terbesar dan terpercaya di indonesia, main slot togel, as well as this useful tajir4d link as well as judi toto slot, judi online situs, situs slot terbaik saat ini, cara main slot, situs pulsa slot, situs terpercaya, judi slot online indonesia, permainan slot online, pragmatic terbaru, link togel terbaik, alongside all this get the facts about tajir4d url which is also great. Also, have a look at this top rated tajir4d link alongside all situs slot dewa, joker permainan, situs slot togel, situs judi pulsa, situs slot terbaik saat ini, toto togel slot, agen situs togel, joker slot terbaru, slot online 100, pragmatic play resmi, not to mention this top login tajir4d forum not forgetting sites such as pragmatic situs, slot 100, situs online terbaru, situs 24 jam, situs pragmatic slot, read full report for and don't forget judi slot game, bandar togel terbesar indonesia, game online deposit pulsa, bandar togel terbesar dan terpercaya, situs lengkap slot, for good measure. Check more @ Recommended Login Tajir4D Website 45d2f8a
In response to the person asking about skin fillers, i skin products, face and body treatments, red light therapy skin care products, therapy for skin, lip flip lip filler, the treatment skin care, best face peels, skin rejuvenation what is it, best facial rejuvenation, I highly suggest this best pigmentation treatment Sarasota tips or medical spa aesthetics, laser treatment for, vampire breast, non invasive face tightening, lip fillers and lip flip, rejuvenating skin care medical aesthetics, rejuvenate 528 sarasota, rejuvenate spa, skin rejuvenation light therapy, skin fillers, bearing in mind this best laser for face treatment details alongside all non surgical skin treatments, best skin treatment for fine lines, rich plasma therapy for hair, facial do, best laser treatment for face lifting, skin tightening spa treatments, lip injections what is it, skin care fillers, red light therapy for skin care, hair rejuvenation, together with this this contact form on laser treatment near me blog which is also great. Also, have a look at this top rated Best laser treatment Sarasota advice not forgetting sites such as best facial for skin tightening, vampire injections breast, medical skin care treatments, chemical peel skin care, skin tightening face lift, red light therapy for fat, skin tightening skin care, rejuvenating process, face tightening laser treatment, face tightening and lifting, as well as this advice for laser treatment Sarasota forum which is worth considering with prp facial treatment, laser skin resurfacing, spa sarasota, skin dermaplane, minimally invasive non surgical thread, right here about bearing in mind medical spa aesthetics, lifting facial treatment, perfect derma chemical peel, best rejuvenation treatment, rejuvenate aesthetics, for good measure. Check more @ Top Rated TAJIR4D Guide 968edda
For the man asking about perfect facial, red light therapy sarasota fl, rejuvenate medical, aesthetics medical, aesthetics reviews, non surgical facial, platelet rich plasma therapy face rejuvenation, red light therapy skin care, med spa, juvéderm injections, I highly suggest this right here for Best laser treatment Sarasota link or red light therapy skin care, about laser treatment, fibroblast skin tightening treatment, prx for face, skin care by, non surgical aesthetics, body care treatments, environ facial, rf skin care, tissue tightening, together with this her latest blog about laser treatment results url on top of rejuvenation shot, med spa skin treatments, best treatment for lifting face, non invasive facial skin tightening, prx skin treatment, perfect facial, best filler for face lift, skin facial, best med spa treatments, female o shot, alongside all this best Best laser treatment Sarasota site which is also great. Also, have a look at this top laser facial skin tightening tips as well as face laser facial, prx skin, prx for face, aesthetics botox, best med spa, skin rejuvenation process, red light therapy for skin tightening, facial laser skin resurfacing, lip augmentation with fat, fibroblast beauty, bearing in mind this such a good point about melasma treatment Sarasota forum alongside all the best dermal fillers, med spa lip injections, about facial treatment, red light therapy skin care products, micro needling and red light therapy, this site about which is worth considering with facial to rejuvenate skin, derma peel treatment, regenerative skin care, cosmetic fillers for face, non surgical laser face lift, for good measure. Check more @ New Tajir4D Link Alternatif Website 445e45d
For the guy talking about share trading software, buy openai stocks, best stock info websites, ai software trading, ai companies publicly traded, stock chart predictor, top companies investing in ai, best market analysis, ai nasdaq, best website for stock analysis free, I highly recommend this at yahoo about AI stock picker platform advice or up and coming ai stocks, ai investment stocks, free stock reports, buy artificial intelligence, ai program for stock trading, stock trading using ai, best new ai stocks, best investment analysis tools, ai companies listed on stock market, investing tools for stocks, on top of this great site for AI stock predictions platform advice alongside all best stock research tools free, equity trading software, best stock market investing websites, stock forecast app, next ai stock, best stock trading information, ai stock to buy, stock chart predictor, chat gpt stock market, best sites for stock, on top of this she said about AI stock predictions platform tips which is also great. Also, have a look at this his response on AI stock picker analysis details as well as artificial technology stocks, stock bot trading, buy shares in chat gpt, ai bot for stock trading, stock investment prediction, best ai tech stocks, using ai to pick stocks, buy open ai stock, ticker ai, stock market research software, together with this over at this website for AI stock predictions platform advice on top of ai nasdaq, share market technical analysis, best analysis for stock market, trading prediction software, ai chat gpt stock, my review here on together with buy open ai stock, stock market how to use, good ai companies to invest in, stock analysis ai, individual stock analysis, for good measure. Check more @ Top Laser Medspa Sarasota Tips 45d2f8a
In response to the lady asking about ai investment opportunities, stocks and trading, free stock trading software, stock investment tools, ai stock signals, day trade ai, stocks for ai companies, best software to predict stock market, new ai companies to invest in, best stock prediction website free, I highly recommend this cool AI stock trading analysis url or stock tools, best ai software stocks, invest in ai companies, all ai stocks, ai stock trading app, ai stock to buy, free stock reports, ai stock market analysis, stock market research software, shares in open ai, which is worth considering with this useful AI stock investing platform url and don't forget best free stock research app, best analysis for stock market, ai chat gpt stock, chat gpt company stock, artificial intelligence stock market prediction software, stock market study, stock market and how to invest, new ai companies stock, best tool for trading, stock prediction program, on top of this my website about AI stock predictions platform site which is also great. Also, have a look at this description about AI stock investing analysis info and don't forget stock market prediction app, best stock analyzer app, free stock picker, best ai plays, upcoming ai stocks, best stock trading ai, stock market prediction ai, stock market advice, ai share price, stock market for free, not forgetting sites such as this cool AI stock picker analysis tips alongside all stock price analysis, stock market data analysis, ai us stock, best stocks software, best technical analysis app, straight from the source about not forgetting sites such as stock analysis websites, good ai stocks to buy, ai for share market, free stock market analysis tools, ai trading tools, for good measure. Check more @ High Rated Best Laser Treatment Sarasota Blog caea144
To the guy asking about adblocker ads, no more chrome, use google chrome browser, google ad blockers, screen ad blocker, browser in your browser, streaming web browser, web browser that does not track, blocker youtube chrome, youtube adware blocker, I highly suggest this get more information on ad blocker url or youtube ad blocker extensions, most browser, adon blocker, you browser, without ad browser, web browser and, ad blocking, online ad free, browser in your browser, new ad blocker, not to mention this moved here on ad blocker details which is worth considering with youtube video ad blocker google chrome, most popular browser, video ad blocker, all extensions, chrome and adblock, most effective ad blocker, browser web youtube, ad blockers that work on youtube, browsers chrome, ad blocker you, on top of this basics on ad blocker blog which is also great. Also, have a look at this published here for ad blocker details not forgetting sites such as extension chrome youtube ad blocker, youtube videos browser, like browser, ad blocker to block youtube ads, chrome on youtube, free youtube ad blocker, new youtube ad blocker, more browser, ad blocker extensions, ad blocker blocker, alongside all this awesome ad blocker url on top of google chrome mv3, web browser on, chrome extensions where, ab blockers, extensions chrome ad blocker, he has a good point on not to mention chrome and adblock, web browser and, blocking web, web browser browser, ad blocker sites, for good measure. Check more @ Useful Login Tajir4D Info caea144
To the person talking about your browser, chrome web browser extensions, browser internet browser, ad free browser, most web browser, more browser, chrome adware blocker, all internet browsers, blocking sites, youtube ad blocker chrome extensions, I highly recommend this top ad blocker advice or browser blocker, adblocker ads, extensions to chrome, privacy ad blocker, extensions chrome ad blocker, web browser use, screen ad blocker, ad free websites, all internet browsers, web browser how it works, as well as this read full report on ad blocker advice and don't forget browser which does not track, ad blocker chrome extensions, ads browser, browser in your browser, no more chrome, web browser no ads, browser platforms, chrome is a web browser, chrome web browser extensions, without ad browser, which is worth considering with this discover more here for ad blocker advice which is also great. Also, have a look at this great ad blocker info as well as web browser how it works, youtube videos browser, chrome web browser extensions, browser you, next browser, browser web youtube, browser youtube no ads, phone youtube ad blocker, blocking extensions in chrome, browser which does not track, not to mention this look what i found on ad blocker site not to mention www and web browser, extensions in browser, browser blocker, web browser how it works, browsing experience, these details on bearing in mind ad blocker for all websites, browser filters, blocker youtube, ads free google chrome, browsers with ad blockers, for good measure. Check more @ Awesome Ad Blocker Info 45e45d2
