Re: Nava v1.0 Firmware
Posted: Nov 10th, '17, 13:18
Vincent,
Could you share hex file for 1.024 firmware, pls?
thanks
lukasz
thanks
lukasz
Enter the world of easy DIY
https://www.e-licktronic.com/forum/
Also keen for this, please share the hex for 1.024.lukep_gdansk wrote:Vincent,
thanks
lukasz
Did the update and no more problem with Expander mode, thanks!e-licktronic wrote:Last update v1.025 online (HEX file included)
No. The last update pre mux is .023. If you have a desoldering iron or you're a ninja at desoldering its well worth giving it a go. You can always revert back. Tbh even if you cut the chips out it wouldn't be expensive to go back.Behaviour wrote:Hi,
Does the 1.025 update work without the MUX mod? The reason I ask is I'm sceptical about doing the mod as I've read it can be problematic on some Nava's
Yes works for me ... look here viewtopic.php?f=24&t=1724#p10568Behaviour wrote:Hi,
hey klang generator,KlangGenerator wrote:3x v1.02 working with the boards here, although I had one pair of MUX_SH boards causing problems in the digital section (OH delay sound). What I do have on all v1.02 are extreme volume differences among each voices. The RIM is 3 times louder than the BD for example.
