MIDI Stopped Working[SOLVED]
I am not sure what happened, but midi doesn't work anymore. When I listen to midi out via MIOS studio, it keeps sending c2 off. If I change the ch., nothing happens. What could it be? Where should I start troubleshooting?Last edited by lalazart on Nov 10th, '18, 02:34, edited 2 times in total.
check connection between I/O and main boards first, after optocoupler...
Thanks for the reply. Luckily I had a spare optocoupler at home, and sure enough replacing it worked!
