I thought i'd start a thread for feature requests.
Here's the first one.
Solo instrument.
[*] In mute mode, pressing shift+instrument would solo the instrument instead of muting it.
[*] Shift+pressing the same instrument again would revert back to the old state and enable the other instruments that are not muted.
[*] Soloing a second instrument while the first one is muted would simply mute the first soloed one and solo the second...
Nava Software Feature Requests
Shuffle and Flam as in the original 909
If you Press the Shuffle/Flam Button in Pattern Step Mode, the Steps 1 to 8 represent the different shuffle values for the Track,
Steps 9 - 16 the different Flam values.
I can't live without Flam
Request for step edit mode:
[*] Pressing shift + note will set the note velocity to either full (127) when off (0). Or to off (0) when the note is at full (127).
[*] Holding a note and turning the rotary encoder will let you cycle the note velocity for that individual step (0-127)
we need FLAM please.
+1 for flam!
Another thing that's bugging me:
- in tap mode, you can't clear an instrument without selecting it first. Imho it would be way better and faster to just hold clear and the specific instrument.
- while holding clear, active steps are played before getting cleared. This doesn't make sense to me and differs from nearly every other instrument i know.
