Mid-Tom continous background tone
  • Those are actually the conga's, not the toms
    Ground the switches ( viewtopic.php?f=16&t=720 ) and the noise will mostly vanish
    are you using an internal power supply?
  • I'm using a wall-wart type external powersupply. I will try grounding the switches. Thanks for the advice.
    The continuos tone is present on both mid conga and mid tom. In the sound file you can hear, when I switch from one to the other.
  • Grounding the switches did not improve the sound noticably. The constant mid tom/conga sound is still there.
    The low and high tom/conga were fine, even with the ungrounded switch housings.
    When I tap with the scope pin 7 of U17, I see a pretty strong signal, when not triggered. At the same point (pin 7 of U15) in the low tom/conga, there is silence.
  • As Fabi303 guessed correctly in a chat conversation yesterday, one of the germaniun diodes is bad.
    The diode tester of my multimeter shows a value other than overload when testing against flow direction.
    Now I have to get some replacement diodes (some, because I also need some to build a distortion circuit).
