v2.003beta:
-Should fix encoder issue
v2.003:
-Fixed led scale bug
-Fixed pattern direction bug
-Fixed LCD special character bug
-Improved accent stability
-Fixed MIDI Clock lag
-Fixed DIN clock out phase
-Pattern start counting from 1 instead of 0
-Fixed Trig1 length when MIDI played
-Fixed group bug
-Improved Track mode fixtures
v2.002:
-First released
Official Yocto² Firmware
Thank you but I need a .hex or .bin file because I programmed with a TL866 programmer.
Please upload hex file. Thanks
Cheers Jos
Cheers Jos
Yes, Vincent pls upload hex file.
cheers
cheers
I have a freshly built Yocto2 where the encoder dial doesn't respond. According to posts on the forum, the way to fix it is to reflash.
I thought I might as well put the new firmware on from this sysex, but neither the 'start+stop' keypresses or the 1+3+5 keypresses mentioned in the user manual bring up any kind of bootloader mode - so how is it possible to transfer this? (Just trying to send the sysex after the Yocto2 has booted up doesn't do anything)
(for those doing the flash with hex - is it possible with a USB-ASP and avrdude? - if so would anyone mind sharing the correct command?)
for programming hex with pickit2:
avrdude.exe -c pickit2 -p m1284p -P -b -U flash:w:c:\tools_y\Yocto_v2_002.hex:i -v
fuses:
avrdude.exe -c pickit2 -p m1284p -P -b -u -e -U lock:w:0x3F:m -v
avrdude.exe -c pickit2 -p m1284p -P -b -u -U efuse:w:0xFD:m -v
avrdude.exe -c pickit2 -p m1284p -P -b -u -U hfuse:w:0xDC:m -v
avrdude.exe -c pickit2 -p m1284p -P -b -u -U lfuse:w:0xD6:m -v
avrdude.exe -c pickit2 -p m1284p -P -b -U lock:w:0x0F:m -v
change your file hex destination and choose correct programmer, pls.
cheers
fuses:
cheers
Can I has hex file pls? I flashed ma chip and it got no bootloader ![Sad :(](./images/smilies/icon_e_sad.gif)
Great! That worked, thanks. I used:lukep_gdansk wrote:for programming hex with pickit2:
fuses:
cheers
avrdude -c usbasp -p m1284p -U flash:w:Yocto_v2_002.hex:i -v
... with a generic ebay USB ASP (all pins except 5v connected, Yocto2 power on). Didn't need to set fuses again. Encoder dial now works. Now awaiting v2.003 hex
![Smile :)](./images/smilies/icon_e_smile.gif)
Still no flam with the latest update?
Thank you for updating the zip with the hex file ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Thanks for the hex file.
Cheers Jos
Cheers Jos
