Push encoder suddenly stop working after firmware update ?
Postby rqckmounted » Apr 9th, '20, 14:59
Hi all
My Yocto v1 push encoder suddenly stop working, the tempo still works but not when I push it
I’ve rarely used my yocto since I’ve built it and this function always used to worked properly but maybe after updating firmware that the problem arise ?
Anyone here have this issue?
Just dont feel like changing the pot if it a software problem
Any help is appreciated
rqckmounted
Re: Push encoder suddenly stop working after firmware update
Postby helectromagneticus » Apr 12th, '20, 02:01
rqckmounted wrote:Hi all
Does the encoder button push work if you go back to an earlier firmware version?
helectromagneticus
Postby rqckmounted » Apr 12th, '20, 12:58
No I tryed to go back but it still does’nt work ?
rqckmounted
Postby helectromagneticus » Apr 19th, '20, 21:47
In that case, it doesn't sound like you have a software problem. Check the connections on your encoder. You can try to reflow the solder joints to see if that helps.
helectromagneticus
Postby rqckmounted » Apr 21st, '20, 14:19
Ok thanks for the tip !! I will check it out
rqckmounted
Return to Yocto v1.0 Hardware
Users browsing this forum: No registered users and 5 guests
