[SOLVED] Very low / noisy HandClap
Maybe they're just easy to fry, I wish I had put a socket there.
Not sure if it would've helped! I used one with mine and had the same result.
Socket is only easyer to change the BA's.
Now i have fryed 4pcs of the BA6110.
I dont put in one again, before i have found the short circuit.
But maybe i have a to low noise too.
Did you find your problem?Croodey wrote:Socket is only easyer to change the BA's.
Also curious if you have found and fixed the problem!Croodey wrote:Socket is only easyer to change the BA's.
Check the first post in this thread:backdoorranky wrote:Also curious if you have found and fixed the problem!Croodey wrote:Socket is only easyer to change the BA's.
viewtopic.php?f=24&t=1137
Even though this was posted by someone else I believe it describes the same issue and how it can be solved.
