LCD still too dim
I'm using the Newhaven LCD from the BOM and I've replaced resistor 694 with a wire. Replacing the resistor helped, but I think the LCD is still too dim even after adjusting the brightness with the trim. It's hard to see in a typically lit room. Is it just this particular lcd model or is the lcd underpowered? Is there another resistor I should bridge?
I'm reviving this posting...
I have the same question as jbdiver.
Anybody found a solution to this problem?
I do use some lcds I had leying around, they seem all to have different resistors inside of them, but mine works with the external resistor soldered to 0 Ohm.
another point, I think the trim resistor is for contrast only, it has nothing to do with the brightness of the backlight led.
Backlight Leds draw a lot of current, so I could imagine your power supply is maybe not made for so much current, can be up to 100mA, that should already be 10% of your rated power..
the Resistor R694(1.2K) in the build instructions is wrong. you have to bridge the R694.
Its in the path LCD Backlight LED supply. The LCD has built-in resistor for LED backlight. so the R694 decreases the current of LED.
