Nava v1.0 BOM [5/18/16 IMPORTANT BOM UPDATE]
Posted: May 3rd, '16, 19:09
Dear Diyer,
Here is the Nava v1.0 Mouser BOM and the complete PDF part list
If you want to save money you can order basic part by Tayda then order specific part by Mouser. Have a look on this topic
To complete your kit you need 26x 11mm Orange d-shaft knob, 1x 21mm black knob and 1x 21mm orange knob. A 15VAC 1000mA psu and a case available on this topic
EDIT 09/14/20
Bom Updated
EDIT 09/04/19
-BFC237086333 Vishay capacitor replace by Nichicon
-20K ohm RN55C2002BB14 Vishay resistor replace by Yageo
-1N5819 StMicroelectronic Diode rectifier replace by Rectron
-56nF Panasonic ECQ-E2563JB capacitor replace by Kemet
-100pF FK28C0G1H101J TDK capacitor replace by Vishay
Bom Updated
EDIT 11/19/18
-MFR-25FRF52-1K8 replace by Xicon
-KCDX-5S-N replace by KCDX-5S-N2
-UVZ1HR33MDD replace by 0.33uF 63V Wurth Electronics
- RGA4R7M1HBK-0511G replace by 475CKR100M
-HCF4051YM013TR replace by NLHV4051DR2G
Nava BOM updated with no backorder components
EDIT 07/16/18
-MC7815CTG replace by SCD7815CTG
- 23PS139 styroflex caps still out of stock
-S471K29X7RP63K5R replace by S471K25Y5PN6TJ5R
-CFR16J4K7 replace by CFR-25JT-52-4K7
-K104K15X7RF53H5 replace by RDEF51H104Z0M1H03A
-TL074CDT replace by TL074IYDT
-885012207072 replace by 08051C104J4T4A
-BOM updated
EDIT 02/15/18
All components are in stock
-BOM updated
EDIT 11/2/17
-MFR-25FRF52-47K replace by MFR-25FTE52-47K
-390pF Styroflex capacitor still out of stock (can be find by Musikding
-BOM updated
EDIT 10/20/17
-Parts needed for the Mux/Sh boards added
-TL074 IC110 replace by a TL072 IC1
-BOM updated
EDIT 04/12/17
-330R Yageo resistor replace by CFR-25JR-52-330R
-2700pF Kemet capacitors replace by MMK5272J63J01L16.5TA18
-47pF Xicon capacitors replace by Vishay K470K15C0GH53L2
-0.047uF Nichicon capacitor replace by QYX1H473JTP
-Abracon 16MHz crystal replace by FOXSLF/160-20
BOM Complete
EDIT 03/10/17
-0.047uF and 0.01uF capacitor quantity updated
-22K Yageo resistor replace by KOA Speer
-100R Yageo resistor replace by new reference
-390pF styroflex capacitor still out of stock but you can find it by Musikding
EDIT 03/02/17
-Mouser BOM updated
-Rubber feet out of stock
EDIT 02/14/17
-56nF Kemet film capacitor replace by Panasonic
EDIT 02/10/17
-1M5 resistor replace reference
-Vishay 0ohm resistors replace by Yageo
-Vishay 100pf 100VDC ceramic capacitor replace by TDK 50VDC
-Vishay 10K trimmer replace by Bourns
-1nF nichicon QYX2 capacitor replace by QYX1
-47nF nichicon QYX2 10% capacitor replace by 5%
-390pF styroflex capacitor out of stock until April. You can find this capacitor by Musikding
EDIT 01/29/17
-Molex 22-01-3067 6 pin housing connector replace by Molex 10-11-2063 (compatible with 7879 series crimp)
EDIT 01/17/17
-Bourns PTV112-4420-B503 potentiometer deleted to the BOM if you received the wrong master potentiometer have a look here
EDIT 01/9/17
-0.1uF 100V capacitors deleted (already present in the BOM)
EDIT 12/27/16
-Bourns PTV112-4420-B503 potentiometer added to the BOM
-10kOhm Yageo Resistors replace by the New Yageo reference
-0.68uF Panasonic capacitor replace by Nichicon
-2N3906 Fairchild replace by MCC
EDIT 12/09/16
-Nava Mouser Bom updated
EDIT 9/13/16
-10K vishay multiturn trimmer replace by Bourns 3296W
-Bourns Encoder non detent replace by 24 detent
-Kemet 0.047uF capacitor replace by Nichicon
-2200uF 35V Nichicon capacitor replace by Kemet
-39Kohm Xicon resistor replace by Koa Speer metal film
--Red backlight 16x2 LCD Still OUT OF STOCK (can find on Ebay)
EDIT 8/15/16
-1K2 resistor replace by KOA speer
-390pF Polystyren capacitor Still OUT OF STOCK (available by Musikding or BanzaiMusic)
EDIT 8/15/16
-Nava Mouser BOM updated
-Red backlight 16x2 LCD OUT OF STOCK (can find on Ebay)
-390pF Polystyren capacitor OUTOF STOCK (available by Musikding or BanzaiMusic)
EDIT 6/8/16
-MF1/4LCT52R105J Koa Speer 1M resistor replace by MF1/4LCT52R105G
EDIT 5/23/16
-Add Kemet R82EC3100AA70J 0.1uF capacitor 7pcs
-1Kohm resistor quantity updated to 29pcs
-1K2ohm resistor quantity updated to 41pcs
-20Kohm resistor quantity updated to 5pcs
-FCI 68000-416HLF 16 pins male pin header added to the BOM
EDIT 5/21/16
-20Kohm resistor quantity updated to 5 pcs
-68Kohm resistor quantity updated to 4 pcs
-100kohm CFR-25JR-52-100K Yageo resistors replace by 291-100K-RC Xicon
EDIT 5/20/16
-100pF capacitor quantity updated to 5 pcs
EDIT 5/18/16
Important update! On semiconductor EEprom does not seems to work with current firmware so you need the Microchip one
-On semiconductor CAT24M01 EEprom replace by Microchip 24LC1025
EDIT 5/17/16
-Nichicon 0.027uF cap QYX1H273KTP replace by Panasonic ECQ-E2273KF3
EDIT 5/3/16
Nava v1.0 Mouser Bom updated
EDIT 09/14/20
Bom Updated
EDIT 09/04/19
Bom Updated
EDIT 11/19/18
EDIT 07/16/18
-BOM updated
EDIT 02/15/18
-BOM updated
EDIT 11/2/17
-BOM updated
EDIT 10/20/17
-BOM updated
EDIT 04/12/17
BOM Complete
EDIT 03/10/17
EDIT 03/02/17
-Mouser BOM updated
EDIT 02/14/17
EDIT 02/10/17
EDIT 01/29/17
EDIT 01/17/17
EDIT 01/9/17
EDIT 12/27/16
EDIT 12/09/16
EDIT 9/13/16
EDIT 8/15/16
EDIT 8/15/16
EDIT 6/8/16
EDIT 5/23/16
EDIT 5/21/16
EDIT 5/20/16
EDIT 5/18/16
EDIT 5/17/16
EDIT 5/3/16
