SOLVED: kick/snare:short decay / ground problem
Posted: Apr 18th, '16, 19:42
by Loons
Hi Yocto DIYers,
I'm having four little problems:
- the first is that my kick has a short decay even at max. In consequence the pitch is not as low as it should...
Does anybody know which resistor to change?
- the second is a short decay for the snare. Does anybody know which resistor to change?
I hope it's not a transistor problem... How can i test it?
-the third is that i needed to adjust r127 to get a 130mV on the Noise section. Is it normal or does i need to change the transistor?
May be it could have effect on my snare...
- the fourth is that the sequencer doesn't accept Roll function in midi sync mode even after I have uploaded the new firmware.
Any idea?
Thanks.
SOLVED: i changer some resistor, and a cap for the snare,
but now hum/ground/interference problem only on the master track, and only when in the metal case....
anybody got idea?
Re: Bass drum and snare, too short decay
Posted: Apr 19th, '16, 09:31
by Loons
I precise a bit:
I higly suspect the HFE of the transistor: what is a good Hfe for the different transistor of the kick, snare and noise?
I will change it.
And for the noise, i'm going to ahieve the Page 15 , service manual modifications.
THX
