is there a way to trigger the accent in expander mode ?
It will be common to all the instruments, I know, but still useful.
Maybe, if it's not implemented yet, each midi note with vel > 100 will enable accent on that "step", doesn't matter which note. Just a rough idea.
Thanks
Accent Trigger via midi [SOLVED]
Sorry, dumb question.
I was triggering the yocto with a step sequencer where the "accent note" was 127 velocity and the "normal note" was 100 velocity.
Everything sounded the same because a normal note in the yocto is 99 velocity. Adjusting the threshold solved all the problems about accent in expander mode.
BR
Francesco
BR
Francesco
