Loosen the nut in on the top, fit the knob, then tighten the nut back up.misa wrote:HI altitude,
in my set I have two larger knobs, but I can't get them on the pattern/track shaft. is there a trick?
thank you for the group buy!
misa
Sifam Knob group buy CLOSED
Thanks RowanRowan wrote:I'm in the UK and my lot arrived yesterday.
My knobs arrived safely today (London) so thanks for putting together the group buy..
All I now need is something to put them on
Paul
London
www.punkdisco.co.uk
www.punkdisco.co.uk
Ah, very well, that mechanism escaped me.. If you have the chance it would be great to exchange the cap for the larger knobs with one that has a white line on top -- much easier to see where the knob is set, especially with the Pattern/Track knob (I usually keep it between Pattern Play and Pattern Edit -- so most of the time the line is facing away from me)Rowan wrote:Loosen the nut in on the top, fit the knob, then tighten the nut back up.misa wrote:HI altitude,
misa
Generally I like the look but the new knobs seem to stand out a bit higher than the original Yocto ones (I guess since they aren't skirted) I'll post a picture soon.
Cut the shafts downmisa wrote:..
Many thanks for putting the group buy together, received mine last week!
Just got my new decal sticker today so I'm nearly finished on the case now!
Very nice looking knobs!
True.. It makes the big knobs sorta unusable, I'm gonna put a drop of paint on it for now..misa wrote:t would be great to exchange the cap for the larger knobs with one that has a white line on top -- much easier to see where the knob is set, especially with the Pattern/Track knob (I usually keep it between Pattern Play and Pattern Edit -- so most of the time the line is facing away from me)
the other knobs look perfect
I can get the caps with the line.
I'm interested. Dunno if it would be economically feasible..Altitude wrote:I can get the caps with the line.
International shipping is ~ $3. I heard back today and they have them in stock
