SOLVED: Sequencer died due to shortcircuit of both boards
Posted: Feb 23rd, '15, 18:10
hello DIY fans!
first of all, thanks for the great project, really satisfied with the sound and workflow.
i got an assembled unit but it needed calibration/exchange of resistors etc.
during the process i made a mistake that i caused a short circuit between the two boards. the sequencer was running and after a second it was fucked up.
when you power the yocto mode-selector is working somehow and changes LED 3,4,6 and a random pattern of steps 2-16.
i guess the voices are still working (fingers crossed).
i tried to find the problem so i found IC4 getting really hot. i changed IC3, IC4, IC5, IC9 but still its not working. IC4 is not getting hot anymore though.
the voltages on the main board is 5V, 14,8V, -14,8V so i guess it might be still a problem with the all the other ICs.
i will swap IC 2,7,8 but then it could be possibly IC1 and IC10.
do you have voltages at several pins to check if they are working?
was it possible to order IC1 and IC10 if i do not succeed? might be something else broken on the IO-Board?
thank you so much, i hope its possible to fix it!
jacob
jacob
