Hi..
Just finished my kit, and it sounds great.
Only have one issue with my Lowtom, the volume is not
working. I can hear the lowtom, and LowConga if switched over.
Tuning is working fine..
Tried to find bad solder, and also measured VR10 pot, to see if something
was shorted. But no luck.
The volume is constant at low-volume..
Any ideas what could be wrong?
Solved: Can't volume Lowtom down.
I've completed the build and it's working and sounding absolutely great except for two volume pots are defective. Don't know if I've heated them too much while soldering or if they where d.o.a, but if I was you I'd start by doublechecking to be absolutely sure your vol.pot is working.
Hi..
Still having those problems..
I have now replaced everything around the potmeter VR10, including the VR10.
All the resistors, capacitors,the 1N4148 and the Germanium diodes, and the PC4558C.
double checked all the solder joints on both sides. Everything is looking fine..
But i can't turn down the Lowtom, it's just there in the mix, what ever i do.
I have no idea where to look next.
Looking at the schematics, the only possible suspects would be C82 & C83, R235 & R238 or U13. Do you have normal volume before the pot?
Yes, i found the problem.. Thanks to ElSchtroumpf..ElSchtroumpf wrote:Looking at the schematics, the only possible suspects would be C82 & C83, R235 & R238 or U13. Do you have normal volume before the pot?
Took a look at the schematics myself, and found that the U13 is located at the Snaredrum section, and
"borrowed" this one amp on the U13.. Replaced the 4558, and now i have have fully functioned Yocto
Just waiting for ElSchtroumpf to send my case
Thanks again
