Fried Regulators?
Posted: Jan 5th, '15, 01:54
Hi there,
I just finished putting together the power supply section and I'm trying to test but getting nonsensical results. I have a 16VAC 1.1 Amp power supply and when using my multimeter and placing negative to ground and positive to +5 and +15 I'm getting nothing. If i put neg to ground and positive to the positive end of D1 or D2 I get a reading of around 18v. If I check D3, nothing.
I've tripple checked the orientation of all the diodes and that i have no bridges or cold solders. Which is why i think i fried IC1 and IC5...
I soldered in IC1 and IC5 without putting on the radiator heat shields (didn't realize they were for the soldering) and I'm pretty sure I got them too hot while soldering them in as to get solder to fill in all the way to the front side of the board.
Would frying the regulators lead to no readings past the first few diodes?
Just looking for an explanation for why im not getting any readings when testing, if anyone has other ideas I'd love to hear them.
Thanks!!!
Thanks!!!
