Comparison between an Original 808 and the Yocto 808
Posted: Nov 21st, '14, 03:28
Hello all,
Yesterday i finally compared my yocto to a friend's 808. His machine is one of the best i've heard over the years.
To compare them, we programmed an identical sequence into both, then slaved them to each other via din-sync, and assigned each output to a different channel on a dj console. We were then able to easily switch back and forth using the crossfader.
We carefully listened to each part separately (1 bar machine A, move crossfader, 1 bar machine B, move crossfader, 1 bar machine A etc.... over and over)
Here's what we observed:
The Yocto Bassdrum had more volume, and also the decay pot had more decay - needed to set the pot to 7 to replicate the setting of 10 on the roland 808. The volume on the yocto was also a wee bit louder.
The high frequency (click part) of the yocto BD was more or less identical, the Sinewave part was tuned 2 semitones higher than the Roland 808.
The snare was pretty much identical at all settings - just tuned slightly differently.
The toms / congas all sounded the same (tone and a decay waveform) however the pitch range was slightly different on them) One of my toms had a different 'decay' sound to the original 808.
With careful tuning, the handclap was near identical.
The clave rimshot sounded identical except for a difference in tuning (about a tone)
The cowbell was tuned to be identical (his is tuned a bit higher than standard C/G). Here i noticed a difference - pitch and tone were identical, but the yocto has a much shorter decay.
The cymbals / hats were also identical except for the tuning.
So, OVERALL:
BD - more volume, more decay, tuning different
SD - very similar, tuning different
TOMS/CONGAS - tuning different in parts, one tom had less decay
CL/Shaker - tuning different
Handclap RS - tuning different RS is quieter..
Cowbell - less (no) decay
hats and cymbals - tuning different.
Volume of each channel slightly different between machines.
Vincent should be commended for such an amazing project!!
Btw Vincent, i want to tune all of the parts so that i can match my friends 808. Would you be able to advise what resistors need to be replaced with trimpots in each voice to achieve this?
Also, how can i increase the decay on the cowbell sound.
Finally, how can i de-crease the decay on the BD - the original limit is fine...
So, OVERALL:
