Only the right half works...
Posted: Oct 20th, '14, 20:05
by touchmonkey
ok so I'm having problems.. Only my cowbell and 3 cymbals are working. I was able to hear some of the other instruments for a minute or two out of the main output but I've lost them. I'm going thru each instrument to double check but I'm wondering if it might be one thing affecting all my instruments? Any thoughts? I'm new at this and not sure what else to look for. I was really thorough with the build and double checked stuff before I soldered it..
ANy advise would be greatly appreciated. Thanks.
Re: Only the right half works...
Posted: Oct 23rd, '14, 12:50
Dear Touchmonkey,
Have a look on the 4pos Molex cables sometimes they break due to moving the two circuits.
I hope this is just a cable problem
Posted: Oct 24th, '14, 16:01
by touchmonkey
Thanks for your response. I will check and get back to you.
Posted: Oct 28th, '14, 23:42
by touchmonkey
Finally got a chance to work on it.
I checked the Molex cables and they appear to be ok. I also went through and checked all the voltages of the instruments and they're fine except the accent which was reading 1.8 volts. But I feel like that is a separate issue? I don't know if the voltage matters in this case but I don't really know what else to do. Can you give me some suggestions on what to test or look for? thank you!!!
billy
Posted: Oct 31st, '14, 09:55
Dear Touchmonkey,
Did you replace the 4011 in the accent section, if not do it ?
Posted: Nov 12th, '14, 14:22
by touchmonkey
That did it! I also had a bad IC in for my rimshot but it works. Thanks so much!!!
My only issue left is that the OH decay time doesn't work. I just have a fixed sound. Any ideas?
thanks again!
Posted: Nov 12th, '14, 16:22
by DeepVibes
Maybe just check that ClosedHH is not muting OpenHH decay by being on the same (actived) step in the sequencer.
Posted: Nov 18th, '14, 20:24
by touchmonkey
It's not that I'm testing with just the OH running by itself. Any other thoughts?
thanks.
Posted: Nov 20th, '14, 00:56
by 4teenth
Jumping in on this thread as I have the same two problems - Decay time on the OH and only cymbals working, (hopefully to be fixed in the same way as the OP
